Matroska XML can handle end-times
No you overlooking nothing. Editing in the Converter is not possible. This would be tooooo much work, for each format. The converter is only for convert from one format into another.
Strange. I don't know and I have never running in such situation.
				Results 151 to 170 of 170
	You'll understand my first thoughts here went to duration usage for proper ffmpeg export.
 You're right of course. And I did some checks. Importing ffmpeg-format.txt in Matroska indeed show all end times - including the last duration.
 When importing mp4 in Matroska only the start times are shown. A bit surprised here, I might have expected same info as for ffmpeg.txt.
	[QUOTE=Ennio;2722297]
 cE doesn't have its own internal mp4 parser, so that was too much effort for me. As nice as the structure of MP4 may be, it can only be used for a few codecs, which I never use myself.
 Therefore MTX is used as a parser and cE processes what MTX delivers.
 But I'm also not sure whether FFmpeg sets the END times itself when you extract the chapters from the mp4 (if I understood that correctly).
	chapterEditor(cE) rev1.43 is available.
 Windows
 Linux
 There is a new cE version with several improvements and a few bugs have been fixed.
 DGDemux version 1.0.0.73 must now be used for BD2mkv because Rocky has made important improvements.
 Code:Change chapterEditor added & fixed * improved # changed % rev1.43 2024-02-12 // chapterEditor & Support for the FFmpeg MetaData format // Chapter Converter & FFmpeg MetaData as output format - Time base adjustable - empty time base corresponds to nanoseconds * FPS calculation now works again for the formats: Celltimes, MeGUI and x264QP // Disc2mkv & Multiple track selection by right-clicking to activate and deactivate the tracks - Click on the checkbox -> all tracks - Click on the track type -> all tracks of the same type - Click on the language -> all tracks of the same language // BD2mkv & Support for specially structured mpls files - removing duplicate m2ts files is not allowed - for a Multi-Edition MKV this mpls must not be the first * Multi-Edition MKV mode: external tracks are now correctly included in the .mtxcfg file again # Multi-Edition MKV mode: better detection of whether mpls files can be merged into a Multi-Edition MKV % Support for DGDemux 1.0.0.73 (settings) - the switch "-sp" was replaced by "-ignorepl" - the "-ch" switch has been removed // Matroska Menu (Medium-Linking) * Source is a folder: all previously loaded files are now correctly removed Last edited by hubblec4; 19th Jul 2024 at 19:12.
	chapterEditor(cE) rev1.44 is available.
 Windows
 Linux
 Code:Change chapterEditor added & fixed * improved # changed % rev1.44 2024-05-30 // chapterEditor & GUI language: Simplified Chinese * the scroll bar width is now determined for each OS and no unnecessary horizontal scroll bar is created anymore // Chapter editors & Automatic chapter names when loading simple chapter formats (settings) // Matroska Chapters & Delete zero-second chapters - applies to all editions and all tabs # Check for duplicate UIDs (editions and chapters) - a duplicate UID is automatically replaced by a new one // Disc2mkv & MKVToolNix --timestampe-scale option for the magic value -1 (settings) - gray status of the checkbox only means for Multi-Edition MKV mode // BD2mkv & Chapter check for a Multi-Edition MKV - list all jumps in the MKV for each edition from the second - change chapter times: individually, all chapters of an edition, all chapters - the time change is always a video frame duration - automatic playback of the MKV file when changes are checked Last edited by hubblec4; 7th Oct 2024 at 20:05.
	After a few year hiatus, I'm finally going through making multi-edition MKVs from some movies, and after doing a couple, I've run into a problem. The worst part is, I only happened to catch it by pure chance, and I have no idea if it's an isolated incident or if there are other issues in the same movie or even in the others I've done so far.
 In the movie I'm currently working on, at one point a few minutes in on the second edition, it cuts the scene off abruptly and quickly and jarringly jumps to the next scene. Playing the .mpls for that edition it plays fine, so it's definitely an issue with how cE is doing things. It's also strange because there are no chapters that start/end at that point in either edition, so I'm really clueless on what the issue could be. I also did a version with the second edition (the one with the issue) first and it was fine, so the problem appears to lie in how cE is configuring it when it's the second edition. I don't know if there are issues with the other edition in that file (the first one in the initial file, now second edition), nor do I know if even the first editions are error-free, since like I said, I only just happened to catch this. Are there log or other files I can provide to help you look into it to try and find the problem?
 Also, it would be helpful if cE allowed switching the editions around without having to completely cancel everything out and start over from scratch, losing all the track configurations. It would also be helpful if it could save project files to allow loading everything back the way it's configured at a later point. For example, if you're able to fix this issue so I can go back and redo this movie (and others), I'm going to have to rename all the tracks, not to mention remember any other configurations I did, and for some movies that can get pretty extensive.
 Finally, why does it allow setting a default subtitle track but not a default audio track? And there should be a commentary flag for audio and subtitle tracks. I always have to remux the output file in order to make these changes, so it would be nice to be able to do them from the start.
	Before I can say anything, I need the disc (structure) to check whats going on.
 Please use my DiscShare tool to create a disc chunk. When possible use the restore option.
 This is not so easy(maybe not possible), because the order of the m2ts files is different and you have to demux the audio streams again.
 Yes I understand you, but this could be a much work, and I have not much time currently.
 cE create a *.mtxcfg file where all the settings are included you made in cE. In MKVToolNix(MTX) you can make other settings and save it as new *.mtxcfg file.
 Yeah, I know, but all this extra settings you can made it in MTX before you mux the MKV.
 In cE settings you can set that cE don't mux the MKV. You have to do this manually: starting MTX and load the *.mtxcfg file.
 Now you can make other settings which are not provided in cE.
 You don't need to remux the MKV, there is a header editor in MTX where you can change all the header settings there without remuxing the file.
	So just use the -r option, or should I use -F and/or -f as well?
 Couldn't it just capture all the entered info, i.e. file name and title, edition names, track names and options and which tracks they're associated with, etc, then automatically do the steps in the background (cancel, start, mpls selection and ordering, reconfiguring everything with the saved info)? Granted, that might be more work than it's worth, which I understand, and I would certainly prefer you spend your time on more core functionality and fixing bugs, but just a thought.
 True. When doing this stuff, I prefer to just make the changes in MTX's main screen and remux, even though it's slower overall, because it's faster for me, so even though the whole process is taking longer, I'm spending less time on it myself, as it's much faster and easier to just select multiple tracks and change one or two dropdowns than to dig through the tree structure of the header editor. Perhaps I'll try muxing manually by importing the .mtxcfg file, seems like perhaps the best solution. I just like being able to do everything in as few steps as possible, so I can just start it and when it's done, it's done, rather than needing me to move it on to the next step. But again, I do also understand you have to prioritize.
	Hi
 For creating the disc chunk use the "-f" switch (full disc structure) and select the both mpls entries in the left list and set the "-r" switch.
 Depend on how many m2ts file are used for the movie so big will be the disc chunk. If the chunk of the disc to big, you can reduce the split-size a bit.
 The restore option gives me the possibility for restoring the m2ts files(in length) on my side.
 Is the disc a normal Blu-rayx or an UHD Blu-ray?
 I understand you, and I had also this idea, but it is really much work.
 But you can save some settings you had made: Disc Title Profiles
 All track info can be saved and reused.
 At the time, I only wanted to use the most necessary track options, since everything else is already available in MTX.
 Of course it would be nice to have everything in one tool, but that wasn't the main concern and so the whole thing didn't have such a high priority.
 And at the time, the "commentary flag" switch didn't exist yet.
	Hi
 Download is running.
 One question about the usage of BD2mkv Multi-Edition-MKV mode.
 Currently it is necessary to demux the Audio streams which you want to preserve in the mkv file.
 Best (and the default) tool is DGDemux.
 Select the audio track and use the demux-Button. The new created demuxed audio file is loaded automatically.
 Check the finial mkv, if there are issues at the transitions, you can use the new feature "Chapter check" to adjust the timings.
 I will report more when the DL is finished.
	I meant to ask about that. I noticed DGDemux is selected in the Disc2mkv -> BD2mkv "Tracks editing program" dropdown, though I don't have it on my computer (never heard of it before seeing it there and in the external programs settings, which it's blank there, too). So I'm not sure if that's even actually working, or if maybe it's making something not work like it should, but I would expect cE to warn that it can't find the program if it's actually trying to use it. I was also curious what the difference is (for this use) between that and eac3to and tsMuxeR, both of which I do have.
 I'm confused by this. Are you saying at some point in the process we need to be loading the files into a separate program (DGDemux) and demuxing the audio stream(s)? And then doing what with them? I just assumed cE was handling all of that, and AFAICT the audio streams have always been copied/muxed into the final mkv properly. I'm not sure what exactly you're saying to do here, when, and why. Can you please clarify?
 And BTW, that link you provided is for a different program, DGDecNV.
	Hi
 First, the Link's will be generated automatically by videohelp, sorry.
 Here is the correct Link to DGDemux.
 The entire story why you have to demux the audio streams is very looong.
 Of course, cE handles everything internally.All what you have to do is:
 1. Set the correct path in the settings of cE to the external programs (cE warns the user if a used program not found)
 2. when the streams can be edited, select the audio track and demux it. there is a Button: "Extract track(s)"
 3. Now is there a new track in the list for each extracted audio
 4. Mux the MKV
 TsMuxeR was the only tool which runs on Linux.
 eac3to was the only tool which is able to remove Audio overlaps
 But DGDemux is now the new best tool and runs also on Linux.Last edited by hubblec4; 25th Jun 2024 at 10:14.
	Hi vertigo220
 I have made an important update for cE. Now it is possible to mux seamless-branching Blu-ray's without demuxing the Audio streams.
 mkvmerge has a bug, but there is a nice feature, so that a workaround is possible for the moment.
 Here is a test version of cE.
	Thank you Baldrick.
	THANK YOU so much for all the time and effort you've put into creating this wonderful, unique and highly useful software!!!
 I have just read through this entire thread which is mostly (by FAR) posts of your constant, frequent updates…
	Hi auralarchitect
 Many thanks for this kind of words.
 I hope I can provide a new cE version soon. I have made wonderful changes for the entire process of creating Multi-Edition-MKVs.
	chapterEditor(cE) rev1.45 is available.
 Windows
 Linux
 After a long time, it's time again.
 "Automatic creation and saving of Matroska tags"
 This is a feature of mine for myself.
 As I always edit the chapters first and save them in the Matroska file, the only thing missing at the end is the tags.
 There is a button that can be used to create the tags, but from there it's always a few more clicks to save the tags in the Matroska file.
 So everything is now automated and when you save the chapters for the last time, you can use the CTRL key to save the tags directly.
 Time stamp files for MKVToolNix (MTX)
 Until now, when films consist of several segments, the tracks should/must be extracted in order to stay synchronized.
 A demux tool such as eac3to or DGDemux is used for this. eac3to was the first tool that could do this and it output a message that
 duplicate audio frames were removed.
 However, there are no duplicate audio frames.
 A user had a great idea, but it wasn't clear to me either what he wanted and how the whole thing should be implemented.
 With a lot of help from the DG-Team, analyzing the problem became much easier (many thanks Rocky).
 It was clear that there were no duplicate audio frames and only the time stamps didn't "match".
 MTX needs a little help to append the segments because the internal append mode works differently.
 With the help of the correctly specified time stamps, which MTX supports, everything can be muxed together cleanly.
 cE had to be expanded to include an m2ts parser because not all information can be found in the mpls.
 At this point, a special thank you to Sherman, who did a lot of preparation for me when coding.
 To create the time stamp files, cE first uses a fast mode.
 For this, only the corresponding frame duration of the audio track is required.
 cE then assumes that there are no more audio frames after the last video frame, which should be the case according to the Blu-ray specs.
 This means that no more audio frames are removed and everything remains synchronized.
 Code:Change chapterEditor added & fixed * improved # changed % rev1.45 2024-10-20 // chapterEditor & support for the file extension ".qp" * Timestamps in the format HH:MM:SS.MS are now correctly rounded // Matroska Chapters & automatic creation and saving of Matroska Tags - only for direct saving in Matroska files with the "Save" button - CTRL key must be pressed for left or right click // BD2mkv & creation of MTX timestamp files for films or Playlists that use multiple segments (settings) - time stampfiles "must" be created only for audio tracks - the audio tracks no longer have to be demuxed -> no more removal of audio frames * mtxcfg file is now created correctly again if DolbyVision is present % in the settings there is a new tab "MKV file" with the relevant settings Last edited by hubblec4; 1st Jan 2025 at 12:05.
  ffmpeg convert from mkv to mp4 [matroska,webm @ 0x1d06640] Read error atBy blurry in forum Video ConversionReplies: 6Last Post: 15th Jan 2018, 06:36
  MKV Metadata TagsBy EspressoMachine in forum Newbie / General discussionsReplies: 2Last Post: 2nd Feb 2016, 14:08
  Latest Unofficial MediaInfo dll for dealing with Matroska Statistic TagsBy ndjamena in forum Newbie / General discussionsReplies: 6Last Post: 22nd Nov 2015, 09:08
  MKV File Statistics TagsBy ndjamena in forum Latest Video NewsReplies: 0Last Post: 27th May 2014, 21:00
  can ffdshow decode mkv matroska files?By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 23rd Oct 2013, 16:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Much appreciated.
  Much appreciated.
						 Visit Homepage
				Visit Homepage
